Did you make the change to $3?
Also, when you say lower-right. Are you referring to how it’s oriented now, or how it’s intended to be oriented?
Again, note that origin value has no bearing on homing direction or location.
I can’t try the homeimg and jog buttons because it first wants to home itself
Did you make the change to $3 from my previous post? It should be set to 2. Make sure Origin in Edit->Device Settings is set to bottom-left.
