X and Y axis directions reversed
Hi, I have a Sharp CNC running the Nighthawk controller from CNC3D that works perfectly using router and laser GCodes in Vectric but when i use Lightburn the X and Y axis jog controls are reversed and the machine thinks the origin is at back right when it is actually positioned at front left. Origin setting seem to be correct. Can i reverse the x and y axis directions in lightburn settings somewhere?
Also when i home the machine it moves to the front left as it should, but the “get position” shows X :430 Y:380.
Shouldn’t it show X:0 Y:0 ???
Try this:
