the atomstack laser cuts in x-axis with a line, in y-axis short lines on top of each other, so its not the same cutting power in both directions, why? What can I do?
There is a minor difference between dot-height and dot-width on most diode laser engravers. This shouldn’t create short lines with noticeable spacing.
For the Layer in the Cuts / Layers menu, is it set to Line, Fill, Offset Fill, or Image?
