X-axis drift with Rotary attached
Recently I bought a PiBurn3.0 and last week I did some testing with it to dial in my power and speed which worked well and I got a great tumbler out of it. This weekend I decided to do some testing with some different graphics to see what looked good and for some reason I was getting a lot of drift in the X-axis. The strange thing is that Its worse with some fonts but not others. Here is a picture of a test I did.
The numbers are the order that I engraved them in. I never touched the cup just did engraves one after the other. As you can see the 1st one looks OK but there is some shift in the T but the other tow there is a lot of shifting going in. Then I tested all 3 at the same time and they all shifted the same amount. Then I did a 5th TEST on its own again and it looked like the 1st engrave.
I did another test this time disconnecting the rotary and just using the XY gantry. I kept the rotary enabled in LightBurn to see if that was the issue and here are the results:
There is no shifting in the X-axis like when the rotary is attached. They is obvious distortion in the Y but that is to be expected because of the 2.5 gearing ratio that the PiBurn has.
I checked all the belts and they are appropriately tensioned. I don’t think there is any slipping going on since using the standard XY gantry I don’t have any issues.
I think it has something to do with the Rotary motor not being the same as the gantry motor and maybe they are getting out of sync for some reason. I used the laser during the week so maybe I accidentally changed a setting and that is causing the issue? I’m not sure. Has anybody had this issue or know what it could be?
Ever figure this out? Seems I’m having the same issue
Post her one project where this occurs, also Save GCode and post here the file for us to look.
