Hello All,
I am hoping someone can help me, I have done 2 days of research on this and have tried several different things and at a loss.
I am running an X Carve 1000 mm X 1000 mm w/ Gbrl 1.1g and having an issue with where the laser starts. I set up Lightburn for a 24" X 24" ( that’s all I need )
Set Basic Settings Origin to bottom left and then home with hard switches.
Issues:
Movement are reversed
When engraving machine moves to upper left corner / images reversed and flipped
Set Basic Settings Origin to Upper Right and then home with hard switches
Issues:
Movement are Correct
When engraving machine moves to upper left images flipped
Also when clicking Get Position X and Y are negative
Things I have tried:
Tried all 4 Basic Settings Origin positions
Tried all 3 Start From on the main page
Homed machine then added G10 L2 P1 X-24 Y-24 (I assume this -24 is in inches)
nothing has worked
$0=10
$1=255
$2=0
$3=3
$4=0
$5=0
$6=0
$10=1
$11=0.020
$12=0.002
$13=1
$20=0
$21=1
$22=1
$23=3
$24=25.000
$25=800.000
$26=250
$27=1.000
$30=1000
$31=0
$32=1
$100=40.000
$101=40.000
“Name”: “GRBL”,
“Settings”: [
“Desc”: “Status: Position reporting ($10)”,
“ID”: “0xa0000”,
“Value”: “Machine Position”
“Desc”: “Status: Show buffer data ($10)”,
“ID”: “0xa0001”,
“Value”: false
“Desc”: “Junction deviation (mm) ($11)”,
“ID”: “0xb”,
“Value”: 0.019999999552965164
“Desc”: “Arc tolerance (mm) ($12)”,
“ID”: “0xc”,
“Value”: 0.0020000000949949026
“Desc”: “Report inches ($13)”,
“ID”: “0xd”,
“Value”: true
“Desc”: “Soft limits ($20)”,
“ID”: “0x14”,
“Value”: false
“Desc”: “Hard limits ($21)”,
“ID”: “0x15”,
“Value”: true
“Desc”: “Homing cycle ($22)”,
“ID”: “0x16”,
“Value”: true
“Desc”: “Max spindle speed (RPM), S-Value max ($30)”,
“ID”: “0x1e”,
“Value”: 1000
“Desc”: “Min spindle speed (RPM), S-Value min ($31)”,
“ID”: “0x1f”,
“Value”: 0
“Desc”: “Laser mode enable ($32)”,
“ID”: “0x20”,
“Value”: true
“Desc”: “Step pulse (microseconds) ($0)”,
“ID”: “0x0”,
“Value”: 10
“Desc”: “Step idle delay (ms) ($1)”,
“ID”: “0x1”,
“Value”: 255
“Desc”: “Step enable invert ($4)”,
“ID”: “0x4”,
“Value”: false
“Desc”: “Probe pin invert ($6)”,
“ID”: “0x6”,
“Value”: false
“Desc”: “X Step pin invert ($2)”,
“ID”: “0x20000”,
“Value”: false
“Desc”: “X Direction pin invert ($3)”,
“ID”: “0x30000”,
“Value”: true
“Desc”: “X Limit pin invert ($5)”,
“ID”: “0x50000”,
“Value”: false
“Desc”: “X Homing direction invert ($23)”,
“ID”: “0x170001”,
“Value”: true
“Desc”: “X Steps per mm ($100)”,
“ID”: “0x64”,
“Value”: 40
“Desc”: “X Max rate (mm/min) ($110)”,
“ID”: “0x6e”,
“Value”: 8000
“Desc”: “X Accleration (mm/sec^2) ($120)”,
“ID”: “0x78”,
“Value”: 250
“Desc”: “X Max travel (mm) ($130)”,
“ID”: “0x82”,
“Value”: 750
“Desc”: “Y Step pin invert ($2)”,
“ID”: “0x20001”,
“Value”: false
“Desc”: “Y Direction pin invert ($3)”,
“ID”: “0x30001”,
“Value”: true
“Desc”: “Y Limit pin invert ($5)”,
“ID”: “0x50001”,
“Value”: false
“Desc”: “Y Homing direction invert ($23)”,
“ID”: “0x170002”,
“Value”: false
“Desc”: “Y Steps per mm ($101)”,
“ID”: “0x65”,
“Value”: 40
“Desc”: “Y Max rate (mm/min) ($111)”,
“ID”: “0x6f”,
“Value”: 8000
“Desc”: “Y Accleration (mm/sec^2) ($121)”,
“ID”: “0x79”,
“Value”: 250
“Desc”: “Y Max travel (mm) ($131)”,
“ID”: “0x83”,
“Value”: 750
“Desc”: “Z Step pin invert ($2)”,
“ID”: “0x20002”,
“Value”: false
“Desc”: “Z Direction pin invert ($3)”,
“ID”: “0x30002”,
“Value”: false
“Desc”: “Z Limit pin invert ($5)”,
“ID”: “0x50002”,
“Value”: false
“Desc”: “Z Homing direction invert ($23)”,
“ID”: “0x170003”,
“Value”: false
“Desc”: “Z Steps per mm ($102)”,
“ID”: “0x66”,
“Value”: 188.9759979248047
“Desc”: “Z Max rate (mm/min) ($112)”,
“ID”: “0x70”,
“Value”: 500
“Desc”: “Z Accleration (mm/sec^2) ($122)”,
“ID”: “0x7a”,
“Value”: 25
“Desc”: “Z Max travel (mm) ($132)”,
“ID”: “0x84”,
“Value”: 94
“Desc”: “A Step pin invert ($2)”,
“ID”: “0x20003”,
“Value”: false
“Desc”: “A Direction pin invert ($3)”,
“ID”: “0x30003”,
“Value”: false
“Desc”: “A Limit pin invert ($5)”,
“ID”: “0x50003”,
“Value”: false
Thank you in advance for any help.
