I just upgraded my X-tool d1 pro (extended bed) with the 40w laser upgrade kit. Everything swapped out without issue. Logged onto xtool and updated the new motherboard. Swapped back to lightburn and started noticing issues I never had with the 10w set up. The laser won’t home which doesn’t bother me too bad because I can manually zero it. I ran the material test under the laser tools tab and it completed fine. I wanted to test a small burn a small project and the burn stops early in the project. I reset everything and it did it 8-10 times
the
