X Y independent Kerf Offset? (Or someway to do it in Illustrator)
I have an Ortur Master and the laser is not a dot but an parallelogram where the Y axis is 1mm and X axis is .5mm in size.
(More here Ortur Laser Master - Laser not focusing to a dot and How small can you make a diode laser spot?)
This means if I want to do some inlay work, I need to offset the path independently in the X and Y direction.
The kerf offset feature in Lightburn is in all direction, assuming a circular laser dot. Is there anyway to have the X and Y kerf offset separate?
Offset path in Illustrator also can’t do two dimensions independently as much as I can tell…
Thank you for your kind reply.
Maybe I shouldn’t have bought a 20w model.
I’ll have to find another way to improve it.
Anyway, once again thank you for your information.
