Im a new user and I have used laser software before but with little experience. My problem is that my x, y, and z axis move in one direction-very little- when jogging. My arrow keys move the axis in the correct direction- when working. It must be in the settings but not sure. Running GRBL 1.1 on Ardunio Uno. The laser is my own design and works very well when running CNC mode. Help would be appreciated. Thanks
A couple things to check:
- Look to see if you have $J jogging enabled in the Device Settings
- If you do, this enforces limits
- Check that your origin is correct and that the working area is positive, not negative numbers
- If you’re not sure what I mean by that, read here: https://lightburnsoftware.github.io/NewDocs/CommonGrblSetups.html
