Hey, I bought the Atomstack X20Pro laser 2 weeks ago, and it worked flawlessly until yesterday. Suddenly, it stopped cutting, but then this morning, it briefly worked again. Shortly after, it stopped working again. I have already replaced the lens and reset the settings according to the instructions with $30=1000 and S-Value set to 1000. Unfortunately, there’s only a small blue laser dot that can’t cut anything at 200mm/min and 65% power for 3mm plywood.
here my gcode of a test
test.gc (6,9 KB)
; Cut @ 1000 mm/min, 20% power
Even with 20 watts, I would only expect this to mark and not cut.
Well But it even doesnt mark
Check if your plugs are well seated at laser head and controller board also check your laser head cables for continuity.
