Does any one know where to get any of the above subject cables in longer lengths than the originals? Due to limited shop space, I could use one about six feet longer than the factory supplied original.
Thanks,
Tim
For an xTool D1 or a Ortur Laser Master 2 20w?
Are you talking usb? How long is the factory supplied?
Generally they limit the length of usb to 3 meters. To be sure, you’d need to know what version of usb it is… 1, 2, 3…
3, 5, and 30 meters. Most likely USB-2. Need a shielded cable to get these distances.
Uh, the real USB length spec is way shorter than the cables available from the usual suspects:
Given the sketchy nature of most cheap cables, even short cables likely don’t meet other parts of the USB spec, as we see with all the communication errors using OEM-supplied USB cables.
Active cables are probably the only way to go beyond the official spec.
Hi.
Absolutely true.
The USB cable that came with my xTool D1 PRO is a prime example of just that, it just didn’t work reliably.
And it didn’t even cross my mind that the cable could be the culprit (one of them
) until I thought “what if…”.
The one I have now is 1.5m (~5’), 3m (~10’) might work, anything longer than that:
might indeed be the only -or at least the best- solution.
Easy to try different cable lengths though, it either works or doesn’t ![]()
Where to get them in Your neck of woods, I don’t know.
Mine are just market variety general cables, nothing fancy.
Regards,
Sam
I had exactly the same experience with my D1 Pro - random and frequent disconnections. I now have a decent quality usb cable and I fitted an extra ferrite bead at the machine end because of the close proximity to the power socket. Since then I have had no trouble.
The cable that came with my S30 Pro is 5’ long and appears to be braid shielded. I extended it with a 6’ shielded cable. Everything is about 4’ from a cycling dehumidifier. No glitches detected in 1 hr+ burns. Cheaper than a powered (active) hub.
I have not had any issues pushing cable length to 25’ or 10m at times without active cables. For this style connection and project I would not push it much farther than this. Here are a few choices of cables.
Thanks for all the replies on the extended length cable I need for the Xtool D1 Pro to the USB 2.0 connection on the PC. Yes my factory cable length is about 3 foot long. I would be comfortable with one about 10 feet. Like I said, this is all because available space in the garage. I appreciate all the replies given, and I will look into the links you have sent me.
Thank again,
Tim
Sirs, here is the cable I am looking for extended lentgh to connect the xtool D1 Pro to my computer.
https://www.amazon.com/MOSWAG-Printer-10Meter-Scanner-Durable/dp/B09PFR16NP/ref=sr_1_3?crid=1215KRKJ5IAMO&dib=eyJ2IjoiMSJ9.zlIak7d79sRZ16iBwEdKheDzNg1aZoCQPYpE50X3zMft5bFccOkwUxfXfkPV_KKcQqcxzyJND4mEjr71IC0uO64jtMkDqMvyQG3YiY89BK78lyr0rFm1_-OTQTmOWqo-o_auKrW45Q-40uvdduA771v0uGNfMowBcbkYTh9VRBtnLzJ-7gNjsFVqY79yx2-BgsbXJFIX6CJyfeyfTc6Y4WYE6_OSB_UfoGokzdRptxU.DCRAvbeB-BN4mYHDjmYt-ZIpxXBaLb0xpIblGJK5SlE&dib_tag=se&keywords=25’%2Busb%2Bprinter%2Bcable%2Bwhite&qid=1709729910&sprefix=25’%2Busb%2Bp%2Caps%2C1074&sr=8-3&th=1
Thanks,
Tim
