I have an xTool D1 pro 10W and I can’t figure out or find any settings that make the laser print in Mirrored image. My test is right on the Lightburn software and it show correct on the preview screen but when I send it to the laser it print/cuts mirrored or upside down. If I design it then select mirror image, then it will print straight like on a coaster. Any help would be appreciated
Can you take a screenshot of Edit->Device Settings?
Also, if you’re actually configured as an iLaser device you’re probably going to have a bad time. You want to be setup as a GRBL device. Check this by pushing Devices button in Laser window. Then click once on the name of your laser. The device type will show at the bottom of that window. Can you also take a screenshot of that?
