Hi Community, a question for all;
Why does over travels just start happening on this Xtool D1 20 watt pro? The other day I ran some parts
over and over with no problems what so ever. As usual, on start up, homed the machine, framed the parts
and then ran them. When the cutting was complete, the machine went home. Today I went out to cut out
some letters, and when pressing start, the machine will travel to the run position and shut down with the over
travel alarm sound. I went into Creative Space and shut down the fire alarm to do not show again thinking
that could be an issue, but no. Before turning on the machine and then starting Lightburn, I manually push
the head into the upper left corner, start the machine and then turn on Lightburn. Proceed to cut out the
letters, then get the alarm when the head gets to cut position. After this which does not work, I press the
home button, the head will home only back to the Y origin, no X position. I see no where a wire hanging or pulling
with the over travel wires. I have even put the letters in the center of the bed and set coordinates to current
position with the same results. Any way, as said, when pressing the home button the machine only homes
in the Y direction with NO alarms, no X home.
Like I said, If I try to cut one letters out in the center of the bed in current position, I still get the overtravel
alarm sound. Has any one unplugged the overtravel wires and worked form the center of the bed outwards,
and figured out how to turn off the over travels in Light burn?
Like I said, the other day all worked fine and today NOTHING.
Machines:
Xtool D1 10 watt with honeycomb, Windows 10,
Xtool D1 Pro, 20 watt with honeycomb and extension kit, Windows: 11 <<<using this today
Ortur LM2 10 watt (not the pro), Windows 10,
Lightburn: 1.3.01,
Thanks always for all the help in the past,
Thanks,
Tim
