Hello together,
I have a problem with my new xTool D1 pro, burning a grid.
The grid in LightBurn looks good - but when I burn it, there is a crash moving the x-axis to -16 (minus 16). This is also shown in a gcode viewer (ncviewer.com)
LightBurn view:
Hello,
because of copy rights, I reduced the content, but the failure still exists! GridLBurn.lbrn2 (153.6 KB)
and this is the GCODE: GridLBurn.gc.txt (113.6 KB)
I think what’s happening is the negative X coordinates are there due to pointer offset configured for the D1. So in order to accommodate the -16 mm offset configured for the X axis the g-code has to go negative.
It’s necessary for the functioning of your laser assuming you are using the crosshair pointer. If you do not use the crosshair then you can remove it.
The reason it’s configured is because the crosshair location is -16mm offset from the primary laser. So you frame with the crosshair but then need to shift for the actual laser operation.
But when I use absolute coordinates, than this is not a good feature. Because with absolute coordinates I do not expect to have a pointer setting that is changing the coords.
