Trying to start up a new xTool D1 Pro with Lightburn but running into a peculiar problem. I have the unit fastened to a sheet of plywood and trying to etch a grid into the workspace. I am able to Frame the the process without issue however when I start the job I consistently get a hard limit trigger error. (attached). The initial file took up the entire workspace. Since then I have tried
A) a smaller design
B) a smaller design that has been shifted away from the origin. (Hard limit immediately triggers at startup at the 0,0 position)
Disable the pointer offset in your device settings. As long as its enabled, Lightburn will try to move -16mm on start because the red cross has a -16mm offset. When you start on your x axis at 0 it will run into your limit switches.
I won’t be able to try this for a couple of days but this certainly makes sense and will be my first step in trying to correct. Thank you, much appreciated.
Entering the $$ command in the Console window should do the trick. Basically, you want enough pulloff that the switch “unclicks” with some room to spare; you can measure that while tripping the switch with a finger and listening (*) for the click.
The GRBL Settings doc may be informative:
(*) Unless your ears are like mine, in which case you’re better off trying to feel the click and unclick against your fingertip.
Apart from reflashing the controller with sensible firmware, I suppose moving the switch a few millimeters behind the current trip point is the only way to get it done.
I had mine in the sunlight of a window and I think it was setting off the fire sensor and stopping the laser! Hasn’t done it since I moved it out of the sun.
