Do we know when Light Burn might support connection to the Xtool D1 Pro through WiFi or IP connection?
im having the same issue with connecting my laser. i connect it thru the usb and it says no laser was found. tried clicking on doing it thru the wifi and also said no laser was found
Never had a connection problem connecting over the USB. Just need to make sure you have the correct com port selected. Use Xcs software to install any updates the laser needs.
No WiFi is a nonstarter for me. I would even tolerate a workaround if I had to go through xcs to upload the file.
Any one find a fix to use wifi?
