I’ve used my xtool D1 for years with minimal issues. However, for the past couple of days the laser is stopping about 10 minutes into a job. The laser stays on but doesn’t move and freezes. I’m not seeing an error code in Lightburn, only the “busy” signal. Nothing has changed in the laser’s “environment” as far as the static electricity build-up goes. I’ve tried 3 separate laptops and swapped out USB cables with a brand new one and still no dice. Anyone got an idea?
I have the same issue. Have not figured it out yet. When I stop the run and start it over it runs ok . I have put on a stactic wire from the motor to the frame because I had stoppiing issues before but it is only in the last couple of days it started again. Running Xtool D1 pro.
