Xtool D1Pro not going back to 0,0 after frame
I have an Xtool D1Pro 20W and we are having problems with getting it to go back to 0,0 after framing. I have cleared the origin, set the origin and set the finish origin to the 0,0…it starts from that position, but after framing a square it goes to what “it” thinks is 0,0, which is actually in the middle of the x part of the frame. When I move the head using the move function to where 0,0 was originally it
This is what we get when we try to return to 0,0 now
Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended.
ok
Did you confirm that you are on latest firmware?
also hard limits shouldnt really be enabled unless you need them
Have you tinkered with firmware values?
Hi! Thanks for responding! We did, and we finally figured out the issue. The X limit switch was broken. We turned off the limit switches and thank goodness, everything worked…including the extension.
Thank you for taking the time to help us troubleshoot…we appreciate it!
Angela
Great news
Do try to get a new set they are handy for replication of work and all that
But glad is working agian
