Xtool F1 with Slide Extension and Lightburn
I’ve seen this asked here and on other sites, but never answered.
Does the XTool Slide Extension, used with an XTool F1, work with Lightburn, and if so how is it set up / configured?
I’m not opposed to using XCS, but I prefer Lightburn and would like to not have to use 2 different apps for cutting/engraving depending on which accessory is attached.
Thank you in advance.
There are basic controls in grbl, but if you add a piece of non-standard hardware built expressly for your machine, it’s unlikely it will function with anything other than the vendors software.
xTool has also done this with the p2, also, where some of the more advanced machine functions are only available using the xTool software.
Good luck
Thanks. I guess I’ll have to settle for using 2 diff software. I had hope since the rotary works with Lightburn, but… oh well.
thanks again
