XTool F2UV and Conveyor with Batch Processing
Does Lightburn support the XTool Conveyor and batch processing ? If not is there any way that Lightburn could enable this functionality in their software ? I am open to any suggestions as well. I use Lightburn with my CO2 laser all the time but I know support for Xtool recently opened up.
Last year the batch processing on my conveyor worked flawlessly in xtool studio. This year it is not working at all, it skips blanks and never engraves them skips the preview step in Xtool studio and when it does engrave it engraves only one or two blanks, and it shifts the engraving. I am hoping that Lightburn can enable the functionality to use the Camera on the F2 and do optical recognition locally to enable batch processing as something changed with Xtools cloud servers with the batch processing.
I was using this machine for production for my business as I have many different shaped items that I need to engrave, however I Batch all the same shapes in the same engraving job. As of now because of failures with the batching workflow production has halted while I have been waiting over a month for a solution so I am desperate to find an alternative whether that be LightBurn or buying another machine that has this same feature I just need to get back up and running
As far as I know, this is the latest on the xTool F2.
:grinning_cat:
From LightBurn’s xTool compatibility notes, F2-series support in 2.2 is listed as preliminary, and camera support isn’t currently available on machines running the latest xTool firmware. I haven’t seen conveyor batch processing listed as supported. Which F2 Ultra UV firmware and xTool Studio versions are you using? If the failures started after an update, those version numbers would help xTool support investigate.
