Xtool - Fire Button
Windows: 10 Home V:22H2 Build:19045.6332
Lightburn: 2.0.04
Laser: Xtool D1 Pro 10W w/USB cable
Tue - Worked fine
Wed - Installed Lightburn 2.0.04 worked fine
Thur - Comupter maybe updated Windows. Long startup. Afterwards Lightburn couldn’t find the laser. Still could see the router when turned on. Rearranged USB plugs. Found laser, lost settings. Created device manually selected xtool controller, it works but fire button was missing. Went to setttings enabled fire button set to 1%.
Have since tried importing older prefs from before updates. No change.
When fire button is selected, button turns red, laser fan comes on, no dot. Pick again, button turns grey but fan stays on. Have to hit stop button. tried 10% same result.
Tried framing, laser comes on frames as nornal except now crosshairs are also on. Went to Xtool software confirmed set for dot.
Laser works normal running projects
