Xtool laser head
Ihave a xtool 10w laser. can I buy a 20w and swap them out?
Hi.
I’m by no means an expert, but AFAiK there’s been several versions of the xTool 10W, so easiest route would be to ask xTool CS.
It should be easy as You probably have the xTool account tied to Your machine.
One thing is certain though, the PS is different but if the upgrade is like the IR head, the required PS is included in the package.
Regards,
Sam
You can, I have a xTool 10w non-pro and swapped the 10w for a 20w. You just need to make sure you buy the correct one. If your 10w is a non-pro you’ll need the 20w non-pro.
