Good morning
I order the xtool P2 55w co2 laser and even tho is compatible with LightBurn some features are not working still, one of them is the autofocus, how do I enter the material thickness into lightburn?
If I have the material thickness on the material library would that automatically tell the laser the thickness or there’s something else I need to do?
You can enter a thickness in the material library, you would also need to ‘Enable Z-axis’ in device settings:
If it is not possible to command the machine to autofocus Z then you would have to discover the offset between the home Z=0 position and the final in-focus position and that would be the value you would enter as material thickness.
