XTool S1 40 with LB will only Home
I have had my XTool S1 for a couple of months and used it with no problem until recently. Suddenly, the S1 will not respond to commands within LB other than Home. The unit works fine using XCS from XTool.
When researching for similar posts, the only thing I found was where a user was trying to move the module while the lid was open which is not my issue. In fact, I can open and close the lid and see the light on the front of the S1 cycle as it recognizes the lid open then close. I have tried restarting the S!, my laptop and even updated to LB 1.7.07 from 1.7.06 to no avail.
Any assistance would be appreciated.
Hey Chuck
I did a search and found this:-
xTool S1 Homeing Issue in LightBurn
If you are experiencing issues with the xTool S1 only homing in LightBurn, it may be due to the commands from LightBurn not being transferred to the machine in a timely manner. As a workaround, you can try using XCS instead of LightBurn for your operations.4
Additionally, ensure that the machine is properly connected and that the LightBurn software is up to date. If the problem persists, you might want to contact xTool support for further assistance.
