Using XCS and the S1 the S2a Pro rotary (in chuck mode) works like it should.
When using Lightburn the S2A pro rotary will run properly but will not return to the origin position when it finished the task. It just stays where it stopped.
The laser module on the X axis returns to origin like it should but the S2A does not.
Is there some setting I have overlooked or is this just an issue to be resolved at a later version update?
Sometimes I need to make a second pass and if the rotary does not return to its origin position that makes it very hard to get the piece properly aligned again.
- Set Finish Position button in the Move window.
- Return to Finish Position switch in the Device Settings window.
- Set Origin button in the Move window.
By playing with these options, you can probably get the laser to finish where you started. HOWEVER, by using the Start From: Absolute Coords in the Laser window, you should be able to just hit Start and run it again.
