XTool S1 issues after Version 2.2 update
I just updated to version 2.2 and tried to engrave from a file I’ve used before with my XTool S1. When I start the engraving the laser doesn’t fire and I get multiple errors 1. I get a pop up that says ALARM:cancel Device reported an error. I hit stop to clear the pop up. in the Console the script says xTool: user start script line 1 dropped - not g-code this machine can run: $L
Any assistance would be appreciated.
This happens to me as well.
In addition to this issue:
When I start a job, the air assist no longer activates.
When I select a saved laser position, the laser head only moves along the X and Y coordinates; the Z-axis position remains unchanged.
xTool S1 20W
Thank you.
Think I found a fix for the $L error. See my Topic XTool s1 Error with 2.2, Will try this out and see if it works.
Tried the fix. Works great now.
What is the solution for this problem?
Here’s the solution he posted:
