XTool S1 only responding to home - Possible cause
(This issue has been discussed in two threads already but they are both closed so I had to raise this as a new one.)
I’ve been using LB to control my S1 for several months with no problems at all.
Suddenly last week I found that the only command which would work with the S1 was the Home button - nothing else in the Move or Laser windows of LB worked. No errors were shown on the LB console.
I then tried using XCS to control the S1 and found that when I tried to start a burn it gave a Baseplate or Riser exception.
Since then it’s been a long journey to fix that exception - a lot of dismantling and refitting screws etc. Today I finally got it to run under XCS without the exception (Not sure how long it will work without giving the exception, but that’s another story…)
But the really interesting thing was that as soon as XCS stopped giving the exception, I tried the S1 with LB and suddenly everything was fine.
So unless it’s just a complete coincidence, it seems that if in LB all functions except home stop working, the thing to do is to try the S1 under Xtool UI, and you will probably have that exception - solve the exception and then LB will work.
Hope this helps
@JoeSpanier - the above could be the solution for the problem discussed in this (now closed) thread : Can not get lightburn to work with my xtool s1 - LightBurn Software Questions - LightBurn Software Forum
Maybe S1 just does nothing with the LB commands if it detects Base/Riser problem - although it seems to acknowledge as if the commands were executed fine?
This is great information. THANK YOU
This theory was confirmed today - everything was working fine with the S1 on LB, then suddenly only the Home button would work. I simply loosened then retightened the three screws on the left hand side inside the S1 chamber, and then everything worked again.(Can’t remember whether or not I power cycled the S1 after tightening the screws. but I don’t think I did)
