Anyone figure out how to adjust the case-light within Lightburn for the Xtool S1? I know within the XCS you can do that, but I’m using Lightburn with a camera installation, and would like to reduce the power of the case light. I’m thinking it can be gcode which I can assign to a macro
I really do think there should be gcode, as in xcs software, you can adjust it.
While I do not have an S1, XCS uses HTTP APIs to send commands and files. You can try using a network sniffer like Wireshark to scan when you change the case light and capture the command packet and see what the command is.
Thank you I will try this tonight.
BR
