xTools F1 Communication Issue
I’m having issues connecting to my XTool F1.
  • I am running Ubuntu 24.04 and have the CH341 driver installed and running.
  • The user is a member of group tty
  • The user is a member of group disk
  • Package brltty has been uninstalled
  • The CH341 says that it has renamed the usb0 to cdc_ether (not sure if that’s helpful)
The Lightburn software cannot find the tool.
Is there some setting or other that I have missed somewhere?
[ 2238.085400] usb 1-4: new high-speed USB device number 7 using xhci_hcd
[ 2238.213450] usb 1-4: New USB device found, idVendor=0525, idProduct=a4a2, bcdDevice= 3.33
[ 2238.213480] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2238.213493] usb 1-4: Product: RNDIS/Ethernet Gadget
[ 2238.213505] usb 1-4: Manufacturer: Linux 3.4.113-sun8i with sunxi_usb_udc
[ 2238.220390] cdc_ether 1-4:1.0 usb0: register 'cdc_ether' at usb-0000:00:14.0-4, CDC Ethernet Device, b2:f6:a1:12:d1:b5
[ 2238.258353] cdc_ether 1-4:1.0 enxb2f6a112d1b5: renamed from usb0
[ 2239.751435] usb 1-4: USB disconnect, device number 7
[ 2239.751942] cdc_ether 1-4:1.0 enxb2f6a112d1b5: unregister 'cdc_ether' usb-0000:00:14.0-4, CDC Ethernet Device
[ 2240.044312] usb 1-4: new high-speed USB device number 8 using xhci_hcd
[ 2240.172378] usb 1-4: New USB device found, idVendor=0525, idProduct=a4a2, bcdDevice= 3.33
[ 2240.172384] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2240.172386] usb 1-4: Product: RNDIS/Ethernet Gadget
[ 2240.172387] usb 1-4: Manufacturer: Linux 3.4.113-sun8i with sunxi_usb_udc
[ 2240.176598] cdc_ether 1-4:1.0 usb0: register 'cdc_ether' at usb-0000:00:14.0-4, CDC Ethernet Device, b2:f6:a1:12:d1:b5
[ 2240.206188] cdc_ether 1-4:1.0 enxb2f6a112d1b5: renamed from usb0
[ 2250.629930] warning: `LightBurn' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
[ 2396.374706] usb 1-7: USB disconnect, device number 4
[ 2690.550308] usbcore: registered new interface driver usb_ch341
[ 2690.550314] ch341: USB serial driver for ch340, ch341, etc.
[ 2690.550315] ch341: V1.7 On 2023.07
Have you confirmed that you’re in the dialout group?
Run groups command and return output please.
Can you locate the device file in the filesystem and show the directory contents? Please capture and post the output.
Do you see any ports listed at all in LightBurn in pulldown? Can you take a screenshot?
Adding to @berainlb you can use
jack@Kilo:~$ lsusb
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 004: ID 25a7:fa67
Bus 001 Device 003: ID 046d:c52f Logitech, Inc. Unifying Receiver
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 005: ID 9588:9899 BJJCZ USBLMCV4
Bus 003 Device 004: ID 056a:0011 Wacom Co., Ltd ET-0405A [Graphire2 (4x5)]
Bus 003 Device 003: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
jack@Kilo:~$
Most of these end up being in the /dev directory… if it made it, might try
ls -l /dev/cdc*
I can identify my fiber on the usb hub with lsusb, but I can’t ever find a /dev entry for it. I powered it off, which is the disconnect in the entry below. Then powered it back on. I get one line in dmesg and there is no entry that I can find or that I know of in the /dev directory.
jack@Kilo:~$ sudo dmesg | tail
[533057.534289] usb 3-4: USB disconnect, device number 5
[533063.436267] usb 3-4: new high-speed USB device number 9 using xhci_hcd
jack@Kilo:~$
Maybe different enough, it doesn’t matter…
Good luck
This topic was automatically closed after 29 days. New replies are no longer allowed.
