setting up Xtools1, “detect”, “focus”, etc. are not in the “console” tab. unable to test these functions at all. ???
Follow the instructions in this post to add your S1 to LightBurn:
Thank you for the quick response and info. I followed your instructions to the “T”, but still no luck. in an attempt to run the focus test the machine made a noise as if it were doing something, and received an “OK” on the console. I clicked “Home Z” and got the same sound of activation with this;
Starting stream
M111 S2
M111 S2
Stream completed in 0:00
I prepared to run a previous project I had saved on Lightburn, but unable to frame or complete any other function. these are the codes showing on the console after pushing the “frame” button;
ok
ok
Starting stream
M17 S1
M106 S1
G0
G21
G54
G91
G0 X0Y-103.968
G1 X103.447S0F6000
G1 Y103.988
G1 X-103.447
G1 Y-103.988
G0 Y103.968
G90
M18
M17 S1
Not having much luck. appreciate your input.
Hello, Make sure your probe is reset. Go itn XCS, and make sure you do not have to reset the probe. Lightburn will not tell you that the probe has an error and needs needs to be reset. I learned this over time. Brian
@gunnyb I don’t have an S1 to test it on my end.
Please try Brian’s suggestion about resetting the probe in XCS.
Can you send us a screenshot of the whole LightBurn window showing the job you want to frame / run?
If you can export your added device and send us the .LBZIP file, I’d like to review your current settings.
