I have a 700x500 bed that’s set correctly in the settings. I’m trying to cut out a project and it’s saying the XY frame is over size. I have shrunk the project down and it still won’t cut it. I’ve turned the laser off and on again. I’ve even tried opening a new project in Lightburn and just making a solid line to cut a sheet of wood and it says the X frame is over size, even when I gave it like 2 inch margins on either side. How do I fix this issue? I just got my laser on Monday and I’m trying to learn how to use it and I’m very new to all this so all of your help is greatly appreciated :)!
How fast are you attempting to run?
I wouldn’t expect that kind of error if you’re just cutting a line. Especially if you gave it two inches on each side…
What are you doing?
Do you mind uploading the .lbrn2 file?
Usually that error means you’re driving it outside of its work area.
Sorry to step in
If your machine has a 700 x 500 bed, the settings for the work area have the wrong value of 710 x 510? check the values
Both Lightburn and firmware have the same workspace size values?
