Hi i have two tree 10w laser.if i put 20*20mm square its does not engrave or cut 20x20 square.it goes to 20 x axis and 40 y axis,
any solutions?
Usually, the steps/mm value in firmware settings is incorrect. Open machine settings, check the steps values in the output section. They should probably be the same for both axis.
