Hi My ortur Laser Master 2 work well using GRBL software (Bought in sept, 2020)
I bought Lightburn software 2 or 3 weeks ago. Version 9.1.19
But when using Lightburn the Y axis is completely OFF (5.5. time the supposed value)
I draw an 1 inch Square the the actual burning result was a rectangle of 5.5 inches in Y and 1 inch in X.
I try to fix the problem by calibrating the Y axis.
It was working on the burning result 1 inch sqaure.
But If I return for displacement for the Y axis the movement of the machine is 5.5 time shorter.
I’m having similar if not the same issue. I’ve tried restoring it back to default settings and imstill having the same issue. Let me know if u find a solution
