Y-axis decalibration
Hello, I have a Sculpfun S30promax,
I have been operating the program for approximately 11 months, today the problem occurred to me as follows:
  • In the Move Option in the console, I can move with the exact measurements in X and Y, But…
  • when I start to cut, in Y it cuts me 55mm higher than the design, causing great deformation in the work
How can I solve this problem?
Check the mechanics: Guide to mechanical adjustments and maintenance Most likely a grub screw of the driving mechanic has become loose, it’s a very common issue and those should be checke regularly.
