Y-Axis is reversed or upside down. Is this a Software or Hardware problem? Sculpfun S9 parade to Sculpfun S22 Ultra
I have updated my sculpfun s9 to a 22ultra.
but now in Lightburn the Y-Axis is upside down:
when I want the laserhead to go up it goes down.
and home is on 0mm 900mm.
is this a hardware or software problem?
You can easily change the y-axis direction in the firmware to restore the usual behavior.
But usually this should not be required. What did you do exactly? Do you use an extension kit?
Post the output of the $$ command in the console window. Then we can reset the direction.
