gwhurrle
(Garrett W Hurrle)
November 21, 2023, 8:55pm
1
DO NOT post your License Key
If your issue requires LightBurn staff attention, please email us at support@LightBurnSoftware.com - this is a public forum
After purchasing my license key, my Y axis moves in the opposites directions. plus moves Negative and Negative moves in the plus direction. Everything was working well while using the free trial version. I have checked the machine setup, plugs etc… and used the Xtool Creation software that comes with the machine and it works correctly. So, I know it must be the software unless I’m missing something.
Dskall
(D Kallenberger)
November 21, 2023, 9:11pm
2
If this is your only problem they can be reversed in edit-machine settings
gwhurrle
(Garrett W Hurrle)
November 21, 2023, 9:18pm
3
I understand, but I’m not seeing where in that window that I can change the Y Axis.
Dskall
(D Kallenberger)
November 21, 2023, 9:30pm
4
Should be $3 pin invert. And then “write” changes.
gwhurrle
(Garrett W Hurrle)
November 21, 2023, 9:34pm
5
Found it! It is already $3
Dskall
(D Kallenberger)
November 21, 2023, 9:42pm
6
Change the true false and write changes
gwhurrle
(Garrett W Hurrle)
November 21, 2023, 9:58pm
7
I can change from false to true, won’t let me change any text. Makes no difference in operation.
Dskall
(D Kallenberger)
November 21, 2023, 10:43pm
10
Try going to console window and typing $3=3 enter.
gwhurrle
(Garrett W Hurrle)
November 21, 2023, 11:15pm
11
Made no difference. Thank you for the help, I’m done for tonight. Other projects to finish.
berainlb
(PY)
November 22, 2023, 5:53am
12
xTool machines do not allow changes to GRBL configuration.
I’m guessing two things:
The Origin setting in Edit->Device Settings is in correct for your machine. It should be top-left.
You didn’t use the .lbdev file provided by xTool to create your device. I suggest you do so as there are other configurations that come with the file.
Operate xTool D1 Pro with LightBurn - xTool Support Center
gwhurrle
(Garrett W Hurrle)
November 22, 2023, 1:41pm
13
Thank you very much! Problem solved! Have a great day!
system
(system)
Closed
December 21, 2023, 8:56pm
14
