Y axis not corresponding
hi, after installing the rotary system on my Sculpfun S9 and having tested it with excellent results, reusing the machine to cut the material I noticed a change in the X and Y axis excursions; I have correctly recalibrated the X axis while I have problems with the Y axis as I have not accepted the recalibration with Lightburn.
ok
$0=10
$1=25
$2=0
$3=0
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=1
$22=1
$23=3
$24=100.000
$25=1000.000
$26=250
$27=1000.000
$30=1000
$31=0
$32=1
$100=34.783
$101=203015.072
$102=250.000
$110=6000.000
$111=6000.000
$112=1000.000
$120=1000.000
$121=1000.000
$122=10.000
$130=410.000
$131=420.000
$132=200.000
If you have a standard S9, then your values are quite off right now. $100 and $101 should be 80. You can set this by sending $100=80 and $101=80 in the console window. Have a look at this page for reference values (bottom of the page): Firmware Update & Settings - Diode Laser Wiki
If you are using a rotary, you should not touch the x-axis setting, this remains at 80. Only the y-axis might change, as long as you don’t use the Sculpfun rotary. In this case, you don’t change any parameters in the firmware. (Small exception: I recommend lowering the y-axis acceleration to 100 to avoid strong slipping). The rest of configuration is done in the rotary wizard of LightBurn, not in the firmware. Maybe see here as well: Rotary roller - Diode Laser Wiki
Thanks a lot for helpfull support!
Before changing ‘things’ on any computer, make a backup of the original. Edit → Machine settings will allow you to load, save, read and write to the controller. So you should have saved them before the modifications to the machine. Then you can save a different file for rotary setting. It’s easy to go back and forth…
Doing this will also carry the information if you slow down any of the axes… I do this quite bit.
You should save it now… then look at File → Load Prefs Backup might have a good copy there…
Good luck
Thanks for the great advice, I proceeded to do it immediately after I restored everything
$101=203015.072 Could this be part of your problem?
Problem as been solved, thanks to all for support.
If you came here looking for an answer, would this be helpful?
Think of this as a payback for the help, it keeps these threads useful instead of frustrating.
Please let us know what you did and mark the thread solved…
Glad it’s up…
Take care
Certainly and I apologize for the delay in answering;
the seller kindly sent me a new motherboard, even if it was an older spare version, and the machine started working again.
