Hi,
I’m using the Xtool D1 Pro 20w
Having a problem with lightburn making a complete square or circle. I made a 20x20mm square & circle my Y axis is 16.205mm and X axis is 19.888mm of the cut piece. Thought maybe the belts were loose, tightened them up a little with the same result. I ran the same test in Xtools program XCS and the the results were 19.812 both Y & X. Any help would be greatly appreciated. Just an FYI I am really new to using lasers and the programs.
Do you have rotary enabled in LightBurn? If so, disable and retest.
WOW!! Thank you so much, that worked perfectly.
