Hi ,i have a problem with the y axis, it doesn’t seem to work
correctly, it doesn’t recognize the coordinates I entered.
Yet when i press homing, it moves perfectly.
I don’t know where you would set the motor current - that would be something to ask on the Awesome Tech forum (I don’t know the Gerbil boards very well).
If the Y is inverted, you might have set the wrong origin value for the device. Where does it think it is after it’s homed? (What is the value of “Get Positions”?)
You said, “I tried to check those things but it still doesn’t work.” - What did you actually do? What are they set to? What are they supposed to be set to? If you say specifics, maybe we spot an error.
