Y axis wrong and reversed
when i home my machine it moves perfectly home
but when i send it to do a job in the y axis its opposite position and upside down
so how do i tell it that i need to reverse it
when i read home location i get 0x -460 y how do i make it 0Y
Is this for the Neje 4 (Max?) listed in your profile?
If so, can you confirm that the machine homes to the top-left?
Are you absolutely certain that it Y is -460 rather than positive 460?
Typically Neje 4 Max homes top-left and will have a home position that read 0, 460.
If this is correct then the reason for your issue is likely an incorrect Origin setting in Edit->Device Settings. This should be bottom-left for your laser. Check and change if incorrect.
Then retest.
Yes my bad 460 but shouldnt it be 0x 0Y 0Z when i place and object in the Y position it goes to the opposite side and is upside down
Not for your machine. Origin is bottom left. So after homing top-left is 0, 460 but bottom-left is 0, 0.
Did you check the Origin setting as described above?
heres what i have but also while i have you can you answer this as you can see I have text and a square in black fill but its not being filled just outlined
This is what I’m saying. Your origin setting needs to be set to the bottom-left position. You are currently set to top-left.
This is likely just the rendering setting.
You can change this in Window->View Style. Change to one of the Filled option. There’s a reason why a Filled view is not the default, however. Always running in filled mode may make it impossible to see certain features of the design so be aware of it.
That all seemed to work Thank You Brother!! whos the Man now point to your self and say I am!!! LOl Thanks Again
