I’m engraving round objects and the center of the engraving should usually align with some pre-existing marking on the object. Therefore I would like to have the origin in the middle of my Y-axis. Is that possible? I can’t figure out how to do it.
Preferable, Leftmost and centered on the Y-axis.
have you considered using a saved position to move the head where you’d like for your rotary set up:
You can use Job Origin for this:
Thank you! I think I understand. I will definitly try that.
