Y movement not working
When I frame the area it shows that it is working fine. However, when I start the burn the laver just burns a horizontal line and does not move vertically.
Need more information. What does it look like when it Frames? Is it an an image or a vector path? Did you select everything you wanted to output to the laser?
It seems to frame normally. It is an image.
Yes As I would normally
An image will scan back and forth. Depending on the LPI setting, it can look like it is sitting still in the Yaxis and not moving.
