I’m having some issues in getting my Z Axis to work in Lightburn. I’ve loaded the “Pre-Release” that allows me to select Z Axis, but it does not recognise the Z Axis Motor, for some reason.
The Fiber Laser is Mopa and has the autofocus function on it. The Autofocus works fine, I can add the job at different levels from the table and press the autofocus and it finds the correct height, so that is OK. What I want to do is be able to set-up templates that will require the focus to be out of focus and was hoping that I would be able to get this done within the software.
If anyone can suggest where I need to look, I would be appreciative.
EzCad2 based lasers would only have z-axis control in the v2.1 release candidates (which is what I’m assuming you’re referencing), but only BSL and EzCad3 lasers have full z-axis support since the official release of v2.1.00 to now (v2.1.03)
If your autofocus is working fine, how is the autofocus enabled/used? If it’s an independent system from the rest of the laser, that may be why LightBurn can’t see the z-axis motor.
Thanks for the reply, yes is an EzCad2 based laser and yes it is an independent autofocus so I’m assuming that LightBurn can’t see it. I’ll have a further look inside the unit and see how it is connected.
