i am using Lightburn to run a CNC desktop router
It has worked fine except for when it moves from one point to another it does not pickup from surface it runs bit to the next starting point then when it reaches that point it raises the bit then lowers it to start. i am sure it just a setting but i haven’t figured it out, any ideas
Hi Edward,
if this answered your question could you go into the reply section and there, maybe under the dots you will see a solved resolved choice, can you mark it as this lets others find answered posts more quickly. Thanks Gary
