Z axis lowers 5 mm on command G0 Z-5, but also lowers on command G0 Z5
Hello all,
I’m running into an issue with the Z offset. I can use the up arrow and down arrow to raise and lower the laser. It responds correctly to the up/down arrow and generates the codes ($J=G91G21 Z5 F600 & $J=G91G21 Z-5 F600) to move up or down 5 mm.
Using Z offset, when moving to the next element in a group on the same layer, the code issues a G0 Z1 and G0 Z-1 command, but the laser drops 1 mm at each command instead of raising 1mm then dropping 1 mm to start the next element. Eventually it would contact the work piece if left to run. Whatever the value is, 1 or -1 the laser descends on either command.
I’ve played with the machine settings for the Z axis and get the same results. MY NEJE seems to process the positive G0 Z1 command as a negative. I get the same results for 1 layer with multiple passes and dropping the laser at each pass, or creating multiple stacked layers with Z offset.
Not certain why it responds correctly to the $J=G91G21 Z1 F600, but not G0 Z1, G91G21 Z5, or just Z1.
Any thoughts would be appreciated !
$0=10
$1=1
$2=0
$3=0
$4=0
$5=0
$6=0
$10=3
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=1
$23=1
$24=6000.000
$25=6000.000
$26=250
$27=1.000
$30=1000
$31=0
$32=1
$40=0.200
$41=10
$42=10
$43=0
$100=80.000
$101=80.000
$102=800.000
$103=80.000
$110=20000.000
$111=19998.000
$112=5000.000
$113=3000.000
$120=1000.000
$121=1000.000
$122=5000.000
$123=50.000
$130=750.000
$131=450.000
$132=45.000
$133=100.000
ok
That suggests the Z axis speed is too high, causing the motor to stall.
The jog arrow codes set a 600 mm/min speed (Z-5 F600) that’s within the motor’s ability, but ordinary moves (try to) run at the layer speed.
This suggests the controller’s Z axis Max rate is set too high.
Assuming the controller permits config setting changes, knock the speed down to what works. In the Console window, type:
$112=600
You can also set the Z axis speed limit to 600 in Machine Settings.
Let us know the original setting, because it’s always amusing to see manufacturer’s aspirations.
Ed, I can’t thank you enough ! That was spot on. That is exactly what was happening and the answer and audible clue were staring me right in the face and I totally overlooked it. I’ve been confounded by this problem for quite a while. I did wonder why the pitch of the stepper motor was so different when the commands were being issued, and the answer is it was being overdriven. The machine settings were $122=5000.000, now $122=600. I tried both variations with multiple passes on one layer using Z step per pass, and multiple layers using Z offset and both now work. The laser head smoothly moves up and down and functions as it should.
Many many thanks for solving this for me !
That’s definitely aspirational! :grin:
You can try increasing the Z axis speed, but IMO that axis moves little enough it won’t have any effect on the total job time.
Fire The Laser!
