I saw some interesting discussion about engraving lathe made russian dolls on a laser. Given that you use the rotary to do the engraving… it seems that a Z axis template could be loaded as well so that it would follow the curvature of the object. Is this possible under LightBurn? I haven’t seen any tutorials to say it can?
GCode based lasers could do multi-axis control like this, but none of the DSP controllers we support will do it. They have very limited Z control, and have no coordinated X/Y/Z movement at all - you can only move Z by itself.
