Reposting this since it got closed without a response.
I’m planning on implementing a motorized Z table into my k40, with a z probe. Now, I understand that pressing the focus z button will just execute the gcode command so that my smoothie firmware on my laserboard homes the z axis to the probe.
If I then enter a material thickness, and set it to “line cut mode”, will it change the z offset to be in the middle of my material?
And if I am doing a job that involves both a scan and a line, will it change the z offset back to the top of the material for the scan, and in the middle of the material for a line? Ensuring that the focus point is correct at all times.
It will not - The top of the material will be used for everything. If you want it to focus at the center of the material you would need to specify a Z offset for the cut (line) layer to push the Z down.
And also, another question, I am running smoothieware, and for my z probe/z upper endstop, I plan to have it attached exactly 10mm above the focal point. How do I tell the firmware to retract 10mm after it has hit the endstop and set that as the zero for the Z axis?
Change these guys around. Where is your Z endstop hooked up, which port? And are you able to explain which way Z moves when you tell it to jog up and down?
I have both a Z-min and a Z-max, it is the Z-min that I want to offset, and its hooked up to the sig and gnd on the Z-min contact. And I don’t really understand that second sentence but Z moves up when I tell it to move up and moves down when I tell it to move down.
So if I have the bed top as the focus point when its correctly homed, and set the material thickness, it will move the z bed so that focus is ontop of the material?
And i’m guessing that after i’ve done that I set the z-offset per layer, depending on if I want to cut or engrave
Right now, when you home the Z, it goes to the top and that is considered 0. So you should set that to either 10 or -10. One of those will do what you want. I think, in theory it should be -10, but you might have things flipped from how I imagine it should be.
