Alf3181
(Christian)
1
Hello,
i have the sbase board with grbl lpc.
so i use a standard 200 steps motor for z axis.
to configiúre the steps/mm so i have 19200steps/mm
but in the machine cinfiguration ist the limit 9999.
if a trick availebal to the 19200 steps/mm or
cann this problem fixed?
i cant by my board the microsteps set lover from z only, if i change the gears so is the power low
jkwilborn
(Jack Wilborn)
2
These are out there working, you have your numbers hosed up somehow.
What did you base those numbers on?
That kind of resolution for 1 mm is kind of excessive, probably more tight than your machine.
system
(system)
Closed
3
