Hey G’day good people,
Any eta on a release candidate for Z control for the ezcad 2 boards please?
Does yours have a Z and a rotary?
I don’t know, so you’ll have to wait for a Lightburn person like @Aaron.F maybe can help you.
I have a EZCad2 board on my fiber, but it doesn’t seem to allow control over the Z axes. I think the hardware can only handle a single items, such as a rotary. But you’ll have to confirm with Lightburn.
Hang in there…
No eta yet, but it might be closer than we think. I’ll ask the devs!
Most EZCad2 controllers (EZ Cad Lite) only have one motor output that’s intended to drive a rotary, but the controller doesn’t need to know that it’s moving a Z Axis.
There are boards with multiple motor outputs to assign to different axes.
@steve22 Can you share the details of your self built laser? Which controller are you using?
Jack is correct, in that the external motors and the galvos can’t (easily) be coordinated simultaneously. In Rotary Mode, we also move the galvo and motor one after the other because of this.
Basic Z-Axis movements already work for EZCad3, and BSL devices.
That’s Homing, and Jogging only. Things like Z-Steps per Pass will be next.
The ezcad2 BJJCZ board most of us have is the “lite” and only has one external axis enabled, but there is the ezcad2 BJJCZ “Standard” board that has 2 external axes. Unfortunately more expensive.
Question: When a second axis control is added to the software, will it be able to target the second axis on a “standard” BJJCZ ezcad2 board?
Hey Jack its not self built is just a standard 100w mopa asian build jpt source, digital controller that almost everyone has nothing special about it. Runs the rotary and your right which has been my argument for a very long time now the software does need to know what the axis is, if it moves a rotary or z axis is moot point. If you can fine tune movement on rotary you can do the same for Z just a different function.
Don’t know if there are limits in the way the Galvo/LightBurn works but maybe you can do a “reverse” math so that with a small diameter translates in < 1 mm linear move for a Z added stepper…
Also increase the graphics by the found value.
Just as a by the by, the xtool software I did have one of their UV lasers for about 6 months not my wheel house and got rid of it.
The auto focus they have is over sold its auto focus to the surface two beams converge and beep beep done.
Their solution for Z Height control is just a step down super simple over X passed you get to nominate how far down and after how many passes the z height drops..
Works in exactly the same way as the cleaning pass, 256 passes do full or partial cleaning pass ever 1 to whatever number you nominate.
Xtool yes I know different machine and board but they do the same thing say 100 passes ever 10 passes drop the galvo head by 0.01 or 0.1 or 1mm you put in the number.
The rotary control works in a similar way you can have the rotary move in increments spin left or right, be it rotary or z height same difference. you may after 10 passes want to put your galvo out of focus do your calculation how far down punch in the number..
You guys had it in a previous incarnation and it worked reasonably well and then ya pulled it lol…
Give it back please:)
Yes, I’m aware ![]()
We didn’t feel like Z-Axis support was ready yet, so we only kept it for EZCad3 machines to run more tests.
It’s more ready, now that we have the dedicated Galvo Move window.
“Z-Steps per N passes” for galvo is on our list, but that requires a major restructuring of how we send commands to the Galvo controller. (Motor signals are “immediate” commands, meaning they are executed directly, rather than being processed from the buffer like Galvo moves.)
I’ll give the devs a nudge to let them know there’s interest.
@LightBurn
Ohhh theres been interest in this for a very very long time from many galvo LB users it slowly evolved from cant be to can be done..
Give them a nudge but dont push them over!!! we want them fit and ready for duty ![]()
