You are right on a number of fronts there, they do claim compatibility with Lightburn lol…
The diode portion of it works
which is something.
Their software is no where near the quality of LB but having said that it does do a good job when slicing a depth map.
Yes it took nearly 12 hours to engrave a 40mm brass coin but having said that it did an exceptional job if not a better result than one would have gotten with LB.
Reason I say that is their software allows for the z height to be dropped by various ranges but it will allow for a 0.01 drop per layer so if you work that backwards through 256 layers about correct weight and the coin did look super nice.
It was a deep engrave nothing missing it was just slow for a low powered unit which is being tested it was more than ok.
So I hear what your saying gcode allows for z drop..
My argument is that LB operates a rotary.. same thing Z drop or Rotary there is no difference as far as the stepper is concerned it moves it left or right or up or down.
So if LB can operate a rotary left or right but we have the rotary port hooked into a stepper driven tower raising and lowering the tower for us lazy people that dont want to wind it up or down.
So LP5 has in its software slice the greyscale and then by what increment do you wish to move the stepper down after each slice.
LB can move the rotary left or right as well why cant it be written by the mighty coders that for every slice we do the same move the stepper to lower Z by 0.01 or 0.02 I cant believe that this is that hard or out of the relms of possibility??
I have to date not heard an argument that says it cant be done.
The benefits to Galvo users is enormous!!! I dont know if you realise how big an impact that would make for fiber laser users.
Its almost like having a 6k fealtek galvo without the active focus and apart from the fealtek being sooooooooooo over priced its not funny.
You would be able to do all your 2.5d work so easily it would be 1000% better than relying on the focal depth of the lens being used.
It would allow for much better use of a lower focal depth lens eg a 70mm and be ok for a 2.5d engraving due to being able to lower the z height in increments.
Yes no am I dreaming?
It sounds simple at least I am convinced it is until shown the boot in the behind and told otherwise.
I just cant see it not being possible you can control a rotary in exactly the same way already..
sigh…
