Z Offset setting issue
When I set the z offset for a layer and I have multiple objects on the layer, for instance +2 for a row of boxes being cut out, the bed will move up then back down on each box.
Can I set it so it stays up for the whole row?
I think optimize Z moves will work. Not familiar with ruida controllers.
Thanks I’ll try that.
Yes, as mentioned above turning on Optimize Z moves will correct the issue. I have the same setting for the Z axis as you show but i do not have Reverse Z Direction checked. But that may be specific to your machine. Below is a test file and what it does:
Z Offset Test File:
Manual Focus before Starting Job
Then Run Job
First Layer - 0 Offset
Second Layer - Moves Down 5mm from Start Position
Third Layer - Moves Down 10mm from Start Position
Forth Layer - Moves Up 10mm Back to Start Position
This is for my Atomstack A70 Pro. Other machines may work differently
Z Offset Test.lbrn2 (20.5 KB)
